subtract values
RIchard, here is something along the lines of scalability. for some reason you want to edit the buttons (bool text) to a different number in the future...the vi will handle those changes, as oppose to changing the constant...constantly  Smiley Wink
Message 11 of 17
(1,030 Views)
Thanks for another solution.
One more question
How can I reset the subtracted value into original value everytime when the time passed midnight?
Message 12 of 17
(1,007 Views)
Use a case structure or a select statement that passes the reset value into the shift register instead of the subtracted value.  You'll just have to work out the boolean conditions to determine that it is after midnight.
Message 13 of 17
(1,003 Views)
OK...set up the timeout case to 100ms, then put your timer function with your reset.once the reset time and the current time are equal, bool out true to reset shift register. there might be a better way of doing this, but I can't think of any at this point. Any suggestions?
Message 14 of 17
(990 Views)
thanks Apok for being a big help! Smiley Happy
Message 15 of 17
(954 Views)
Hello. I have a same problem too
There will be the list of values in array.
Then select a value to subtract.
I do not want to subtract the whole list at one time.
I just want to subtract one value from the list.
Please help. Thank .
Message 16 of 17
(916 Views)
Considering what I've understood, Delete From Array function suits your needs.
Regards
Mondoni
Message 17 of 17
(906 Views)
