subvi always open
In development mode, when I open my main vi, a subvi always open as well.  What can cause that?
Kudos and Accepted as Solution are welcome!
(3,285 Views)
Maybe your subVI is set to "show front panel when called" from its vi properties..?
(3,282 Views)
or "show front panel when loaded" from its vi properties..?
(3,279 Views)
Accepted by jyang72211
It is likely the Show Front Panel When Loaded property.  It can be found in the Window Appearance of the VI Properties (you will need to use the "customize" button in order to actually find the property).
(3,270 Views)
show front panel when loaded is it.  It was greyed out, so I wasn't aware of it.  Thanks!
(3,246 Views)
