subvi output not working
I am using a GPS VI that is working properly as a subVI in a Main function but the outputs of the subVI are not displaying in the Main. Could anybody help me. I appreciate it.
(3,788 Views)
As i understand it your sub-vi gets stuck in an infinite loop, thus no output. The express vi will be constantly fed with old data as you're using local variables (just wire directly from the string to number).
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,779 Views)
Of course not. You don't understand LabVIEW and dataflow (or even how while loops work). You call the subVI and pass execution to that. Your subVI has a while loop that can only be stopped with a front panel boolean. Nothing will return from the subVI until it finishes execution but since you have no way to stop it since it's front panel is not made visible, nothing is getting passed back and you have to stop everything with the abort button. Get rid of the while loop in the subVI since you have one in the main. Get rid of the local variables in the subVI because that is bad coding and you have a race condition. Move the VISA Initialize Serial Port and VISA Close to the main VI (outside the loop) because you only want to do them once.
(3,778 Views)
