capture card specifications
What specifications should be met for an image / video capture card, such that I will know that it works with Labview?
Thank you.
(2,862 Views)
Accepted by topic author timjm
Are you referring to a frame grabber for a camera? If you want to know whether a non-NI frame grabber can be used with Labview, see this KB: Can I Use My Third-Party Frame Grabber with the IMAQ VIs?
Misha
(2,857 Views)
