How do you count the frequency of a boolean signal?
Hi, I'm new to LabVIEW, so I suspect this is propbably quite a simple problem.
I'm developing an optical tacometer for a model gas turbine engine. I have a boolean signal in labview which is switching at a frequency between 4 and 26Hz. I need a live readout of the frequency of this signal.
Does anyone know how I could do this? Any help would be really appreciated!
Many thanks
Will
Message 1 of 27
(6,439 Views)
How are you acquiring the signal from the tach?
Message Edited by deskpilot on 03-10-2010 11:59 AM
Message 2 of 27
(6,421 Views)
How are you truning on the boolean? What does your code look like so far? How accurate does the frequency need to be?
I guess I would make an array of time and boolean state and get a running average for the cange in time vesres the state of the boolean.
Tim
GHSP
Message 3 of 27
(6,416 Views)
The Boolean signal is coming from the digitial input of an I/O board, which is triggered by a phototransistor. The signal is acquired thorough ActiveX.
Message 4 of 27
(6,412 Views)
Because the frequency of the signal is so low, I imagine the update frequency must also need to be quite low. If the system gave an updated frequency reading every 2 seconds, that would be great.
The system doesn't have to be that accurate. ±5% would be okay.
Thanks for your help.
Message 5 of 27
(6,407 Views)
frequency = event/time
so basicaly what you need is to take differences of time and then invert the value.
i'd try with an event structure.
advice: make sure you are always counting the transition from 0 to 1, or from 1 to 0. that is the instant at which the boolean variable goes from false to true or viceversa.
Message 6 of 27
(6,390 Views)
Can you suggest any VIs to get me started? I've found a VI which detects the transition of a boolean source from TRUE to FALSE, or visversa. Could this form part of the solution?
Thanks for your advise
Will
Message 7 of 27
(6,384 Views)
Will
Can you post the VI you are using to capture the boolean input. May spark some ideas.
Herrlin
Herrlin
Just trying to spread the LabVIEW love.
Message 8 of 27
(6,376 Views)
Accepted by topic author Will15648
This vi should work for you
Tim
GHSP
Message 9 of 27
(6,373 Views)
Works perfectly! Thanks very much.
Message 10 of 27
(6,333 Views)
