03-11-2010 07:38 AM
03-11-2010 07:43 AM
aeastet wrote:
Here is a simple example of waht I did. If you change the loop time the cal freq vi does not care.
Im not following you becasue if you change the loop time the freq changes.
03-11-2010 07:45 AM
Will15648
wrote:
.... I need a live readout of the frequency of this signal.
Herrlin wrote:
I still would like to see how Will is getting his data from
the digitial IO. In my mind for this code to kinda work the data would
have to be streaming real time.
Based on the first request on this tread it got the impression that it was a live measurement.
03-11-2010 07:47 AM
03-11-2010 07:53 AM
All I’m saying is without knowing the device sampling rate you can’t accurately figure out the frequency. I feel that it is poor practice to use system time to determine sampling rate. As far as the LIVE frequency goes that’s the frequency out that is live not the input.
03-11-2010 07:55 AM
03-11-2010 03:47 PM - edited 03-11-2010 03:53 PM
After reading the initial post, here is a test bed example:
