sum array of clusters column
How can i sum an array of clusters anyone column? Like attachmend array of clusters  example.
(3,724 Views)
Accepted by keremgeliz
Use a shift register on your FOR loop to hold the sum.  You add the current sum with the current cluster's value and put the value in the shift register.  You will need one for each sum you want to take.
(3,720 Views)
Thank for your help now its working perfectly.
(3,713 Views)
Try this:
(3,708 Views)
No, that's not good:
  • You are creating extra array allocations, just to take the sum later and reduce it back to a single number.
  • Your shift registers has absolutely no purpose because you never use their value and never initialize them.
Compare with my solution above.
(3,704 Views)
