swap background image?
I am looking for a posibility to dynamicaly change the background image of a vi.
See attached example: The switch should change the circle-image into a box-image. the two images are overlaid and I thought I could make one image visible and the other invisible, but the images have no terminal in the block diagramm...
Any idea?
Greetings Johannes
Using LabVIEW 7.1 and 2009 recently
Message 1 of 9
(5,726 Views)
Now i tried to insert a picture in my vi and read a box-image or a circle image, depending on what I want as background.
How do you like this idea?
I have some problems loading and displaying the picture - I have no idea how to convert the jpeg-data into "picture-data". see attached vi. I have no idea what's wrong and I can not find any "jpg-to-picture"-vi     😞
Greetings Johannes
Message 2 of 9
(5,713 Views)
Why must the image have no terminal?
a picture box control or a custom boolean is an easy method for doing exactly this,
The hard way with no terminal is to get a reference to the decoration (not easy since the decorations do not have lables and are an indexed object of the pane on which it resides).
There is also a pane image property to change the entire background.  I would stick with the picture box control if it was me (make the borders transparent).
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 3 of 9
(5,712 Views)
Thank you Paul. As you can see, that was my idea too 🙂  But I have stil problems
Greetings Johannes
Message 4 of 9
(5,706 Views)
See attached:
Paul Falkenstein
Message 5 of 9
(5,703 Views)
Accepted by topic author johanneshoer
You will need a down convert for 7.1. Dont have it on my PC.
I used a picture ring Make the images with decorations (btw use a gif allows for transparent images on import) and pasted them in the image ring. took about 30seconds.
Paul Falkenstein
Message 6 of 9
(5,698 Views)
I can not open LV 9.0-VIs
Could you please either save it as 7.1 or upload a screenshot?
Thanks.
BTW here is a screenshot of my problem:
21243iCA136C42F2003265
Greetings Johannes
Message 7 of 9
(5,692 Views)
Ok,
thanks! It works well with the image ring 🙂
Greetings Johannes
Message 8 of 9
(5,686 Views)
Try putting the Draw Flattened Pixmap VI where your broken wire is.
Message 9 of 9
(5,676 Views)
