sweel
 How to make this example in LabVIEW , anyone , to help?
Swell   Model
X(t)=A ( 1+α ( u(t-t1)-u(t-t2))) sin(wt)
t1<t2,  u(t) = { 1, t>= 0  ; 0, t<0
parameters
0.1=< α=< 0.8
T =< t2-t1=< 9T
Message 1 of 18
(5,764 Views)
What do you mean you want to "make" that model?
Do you want to graph it? Solve it?
What do you have done so far?
Cory K
Message 2 of 18
(5,750 Views)
Hi goce,
here's a bigger part of your homework:
Message 3 of 18
(5,747 Views)
I want to show it in a graph, a tried to , but but didn't succed, this is what i get in a graph.
Message 4 of 18
(5,745 Views)
Message 5 of 18
(5,742 Views)
Hi Goce,
it's a snippet ready to use... Smiley Wink
Message 6 of 18
(5,728 Views)
Thanks GerdW , but I can't find the way to edit the snippet, can you please give me the .vi , beceause I want to show the signal in a graph
Message 7 of 18
(5,721 Views)
It's a LV2010 snippet; Goce's using 8.5.  A Code Capture Tool snippet can automatically save to older versions and GetSnippet (JKI RCF required) can extract them in pre-2009 LabVIEW.  I made this LV 8.2 snippet in LV2010.
Jim
Message 8 of 18
(5,719 Views)
Thanks, but there is still a problem, I can't see the graph, which I think that it must to be something like this in the atach.
Regards
Message 9 of 18
(5,705 Views)
Gerd's snippet will not give you a graph because it calculates a single number.
All of the variables are set to controls, so the user would set each one of those numbers, then his code will calculate the result.
If you want to graph one variable vs the result, you can use his code as a subVI, then pass an array of values in, and hold the other variables constant.
Cory K
Message 10 of 18
(5,701 Views)
