sweel
Thank you,I'm new in LabVIEW , and please If you know make it, and attach it, I want to see the way it is made, because I will must to make similar graphs, I want to learn it.
Message 11 of 18
(1,371 Views)
We cannot make anything until you let us know what you want.
You keep saying that you want to graph this model, but you really need to specify what is being graphed.
Do you just want to graph t vs X with all of the other parameters held constant?
Cory K
Message 12 of 18
(1,363 Views)
As I think , I must to recieve a graph like in the picture that is attached, and that parameters must be in those borders. This is a Disturbance swell model, I think.
X(t)=A ( 1+α ( u(t-t1)-u(t-t2))) sin(wt)
t1<t2,  u(t) = { 1, t>= 0  ; 0, t<0
parameters
0.1=< α=< 0.8
T =< t2-t1=< 9T
Best Regards
Message 13 of 18
(1,361 Views)
Hi Goce,
why do you attach the picture repeatedly and also repeat the formula? There is nothing new in the post - and you already got an implementation of that formula...
Message 14 of 18
(1,339 Views)
Here is an implementation of the code that was given to you above.
... along with the exact advice on how to implement the graph you are looking for.
Please listen to advice when it is given to you, and at least try it.
Cory K
Message 15 of 18
(1,324 Views)
I can't open your document, because I have LabVIEW  8.5 v .In the attach is the VI that I created so far.I separated the components from the formula in a 3 parts .
I wan't to generate array  and to create a graph.
Best Regards
Message 16 of 18
(1,322 Views)
here it is.
Mike
Message 17 of 18
(1,302 Views)
@MikeS81 wrote:
here it is.
Mike
Thanks Mike
Cory K
Message 18 of 18
(1,299 Views)
