switch between option pages
Hi
When i running the VI i want to change to page2,but i can exchange the pages,could someone tell me why i can not change the pages.
(3,698 Views)
Accepted by 314159ym
Ok,i fix it by change the property of option card
(3,670 Views)
@314159ym wrote:
Hi
So you want to change, but you can exchange? But you want to know why you can't change? Hmm...
My guess is the TabControl is disabled. Right-click>Advanced>Enable State should be "enabled".
You might want to post the VI. It's hard to tell from an image.
(3,668 Views)
Hi
Thanks,it is fixed by change the property.
(3,663 Views)
What property?
(Make sure the tab is a control, not an indicator)
(3,635 Views)
the property of the control tab make it "work"
(3,605 Views)
So enabling the control with the "Enabled" property did the trick.
This could also be done through during edit time, by right clicking, Advanced, Enabled state, enabled. Both methods have the exact same outcome.
The property node will be executed every time it is run. It can be deleted once the control is enabled. Unless of course, some other the code disables it again. Then it makes sense to use a property node to enable the control at every run.
(3,598 Views)
