switch - connect 2 channels
This VI is what I think I need. I need to be able to switch between 2 channels and taking some measurements. I need switching because I intend to take measurement with a resistor connected and without without physically inserting and removing this resistor. My issue is I am right now using the virtual DAQ but I cannot run this VI I can find to the Configured Topology. Can I get some assistance with this? Thanks
(2,600 Views)
What's wrong with just making a task with both channels.  Then you have both sets of data.  You can read multiple channels out.  Just use Index Array to get the channel data you want.
GCentral
(2,594 Views)
Yomi,
Please refer to this example.
Best,
Carmen C.
(2,564 Views)
