system.drawing.graphics
Dear
I want to use System.drawing.graphics class in LV
In attached file, Image class can call property, method without constructor.
But, when Graphics could not call property, method without constructor,
it is happen error as attached file.
and Graphics do not create class in constructor.
How can I ?
Bongchan Park
Message 1 of 8
(7,134 Views)
Hi Bongchan,
Please refer to the attached images.  You have to use the .NET functions almost like you would in Visual Basic/C#.  Thus, the program is structured like so:
1. Create an instance of the System.Windows.Forms.Form class
2. Register the event Form_Paint that will invoke the callback VI
3. Create a graphics object from the PaintEventArgs passed into the callback VI
4. Create an image object that loads the picture file
5. Call the graphic object's method DrawImage using the image object
Here is the corresponding C# code:
name GDI_Test
   // Create an instance of the System.Windows.Forms.Form class
   public partial class Form1 : Form
      public Form1()
         InitializeComponent();
      // Register the event Form_Paint that will invoke the callback [Function]
      private void Form1_Paint(object sender, PaintEventArgs e)
         // Create a graphics object from the PaintEventArgs passed into the callback VI
         Graphics g = e.Graphics;
         // Create an image object that loads the picture file
         Image test = Image.FromFile("C:\\test.png" );
        // Call the graphic object's method DrawImage using the image object
        g.DrawImage(test, 0, 0);
Steps 1 - 2:
Automatically create the callback VI by right-clicking on the VI Ref and selecting "Create Callback VI":
Steps 3 - 5:
Message Edited by Pakman on 08-18-2008 09:48 AM
Message 2 of 8
(7,058 Views)
Accepted by bc7041
Just out of curiosity, what do you need to do with that class in terms of drawing? The LabVIEW <--> .NET interface is not known for its speed, so you may wish to consider using the native drawing tools in LabVIEW.
Message 3 of 8
(7,052 Views)
How do I do step 1 - 2?
VI, Block Diagram, Functions, Connectivity, .NET, Register Event Callback placed. Members are Event, VI Ref, and User Parameter. Selecting Event says "No Events". If I open a LabVIEW example (e.g. NET Event Callback for Calendar Control.vi) I am able to disconnect all wires from it. select Event, and get a list from which I can pick Paint. Then I can drag it to my VI.
Similarly, I select VI Ref and and Create Callback VI is grey (disabled).
Message 4 of 8
(6,688 Views)
After creating the VIs as shown the caller runs but the image is not displayed. A break point in the callback is not triggered. What is the LabVIEW code that corresponds to the following C# code?
// Create an image object...
Image test = ...
Message 5 of 8
(6,673 Views)
Nevermind about Image. I had a wire mismatch. The callback still doesn't break point but I don't care because the graphic appears on the Form. I still wonder how to start from a new Reg Event Callback though, instead of modifying one from an example.
Message 6 of 8
(6,655 Views)
To start from a new Reg Event Callback, you connect the reference from the Form .NET constructor into the Event terminal of the Reg Event Callback.
Peter K.
Message 7 of 8
(6,652 Views)
I couldn't find the Reg Event Callback for a while either, but turns out it's just built in to LabView.  It is located in the .NET Palette, or you can just Ctrl+Space and search "Register Event Callback"
Message 8 of 8
(5,300 Views)
