system exec not running copy command
zou,
I tried using a batch file but I get the same error that the file doesn't exist if I run the batch file using system exec.vi. If I double click the batch file in windows explorer then the command executes successfully and the file gets copied to the destination folder.
mikereporter,
If I use labview path control and use the browse path to system32 folder then I don't see query.exe(the file that I want to copy) in the results.
Message 11 of 15
(2,558 Views)
@LVCoder wrote:
zou,
mikereporter,
I wonder if this has anything to do with UAC?  I know LabVIEW has problems sometimes with UAC on at any level.
Bill
CLD
(Mid-Level minion.)
Message 12 of 15
(2,547 Views)
Accepted by LVCoder
My guess would be that your Windows is 64 bit and your LV is 32 bit and you're getting redirected. See here for a similar recent discussion with more details - https://lavag.org/topic/19387-system-directory-hidden-from-labview-not-really-a-labview-problem/
___________________
Try to take over the world!
Message 13 of 15
(2,520 Views)
Thanks tst! that exactly was the issue.
Message 14 of 15
(2,500 Views)
Wow, I knew you could trip over this issue with the registry - I didn't realize it applied to the system32 directory, too!
Bill
CLD
(Mid-Level minion.)
Message 15 of 15
(2,491 Views)
