Showing results forĀ
Search instead forĀ
Did you mean:Ā
tab
Hi there..i need some help..i use 2 tabs. can i change the tab display according to the function that i choose that shown in the tab.jpg. for more information please refer to the attachement file.i want to change page2 according to the enum function. for example if i choose over voltage in the enum function, so i want the tab display page2 become over voltage. can i do that by using tab property nodes??..thanks..
(4,511 Views)
You can specify which tab is displayed using the Value property
(4,509 Views)
I don't see a tab.jpg or an enum function. did you attach the right stuff?
Do you want to programmatically change which one of the two tabs is visible or do you want to change the text on the tab?
(4,505 Views)
sorry..i hav attached the wrong file...this is the right file
(4,481 Views)
hi again..
let say..i have 2 pages.so i want all pages are visible.i juz want to change the text on the tab. and if i have 16 pages..if i change the text on each tab, what will happen to my program??is there will be cany conflict occured??
(4,479 Views)
Are you change the text programmatically?  I don't see why this would cause a problem, but I'm not exactly sure what your question is.  If I understood you right, in your first post you stated that you wanted to change the display on one tab, according to what was selected in the enum control.  You can do this by wiring the enum control to a case structure.  You might want to explain what your overall goal is with this application you are working on, that way there will be less confusion.  Thanks!
(4,444 Views)
