tachometer:: speed become zero during work
HI
i have a a tachometer that conenected to motor shaft
the output of this tachometer is pulses and each 24 pulse give a 1 revoluation
i use labview FPGA to estimate the pulse frequency  with LV VI that already provided by NI as shown in figure (1) the loop tested under 5MHZ
the problem is shown in figure (2)  where during DC rotating the pulse frequency go to zero for then back again to normal.
this cause a problem in my speed control system.
best regards
hi ?Q>
(3,392 Views)
debounce your input.
Stu
(3,387 Views)
Really !!! As I read before the bounces happened in switch ??
hi ?Q>
(3,355 Views)
Hi mangood.
Probably, Stu is right. Here is a little document that might come in handy.
Rudimentary Circuit to Eliminate Glitches/Bounces on a Signal
http://digital.ni.com/public.nsf/allkb/93FA5F2325B220108625724500740A1D?OpenDocument
Fabián M.
Internal Sales Engineer
(3,321 Views)
@FmTesla wrote:
Hi mangood.
i will try
hi ?Q>
(3,313 Views)
I recommend a simple software debounce.  it has been very effective in the past.
any equipment that vibrates and product spurious edges on a tach or encoder.
see attached.  it is a modified version of one from NI  set n= 5 0r 10 for your case and see how it works
Stu
(3,299 Views)
