tachometer.vi
I do not have LV7.1. Although I have LV7.0 30 day free trial package. Would the Frequency VI work?
Message 11 of 16
(1,607 Views)
I know we've mentioned this before. But you really need to be using LabVIEW 7 and DAQmx. If you only have a 30 day trial, then you NEED to get a license of it. It will really make things easier when you are programming your application.
Once you are in LabVIEW 7 and DAQmx. Look through the shipping examples. Try to understand DAQmx and how it works. Also look through the many LabVIEW 7 and DAQmx tutorials we have available.
-Sal
Message 12 of 16
(1,597 Views)
I have a LV in 6.0 that measures FORCE from a BALANCE and frequency of a motor using the frequency COUNTER from the NI-6025E DAQ card. So far I have not been succesful. I get the message ERROR-10401 - CTR GROUP CONFIG. What does that mean? The LV has no ERRORS. Anyone can HELP! The LV in 6.0 is attached.
Message 13 of 16
(1,575 Views)
Why don't you try a value of "1" for the counter input?
Message 14 of 16
(1,559 Views)
By counter input do you mean the frequency.vi input which is now zero? What does the ERROR means in plain language?
Message 15 of 16
(1,549 Views)
Yes, the counter input of Measure Frequency. You have counter group 0 specified. I'm pretty sure that counters start with 1. It would seem that a CTR GROUP CONFIG error means that you're trying to configure an invalid counter.
Message 16 of 16
(1,534 Views)
