tangent of arcTangent
i try to test the tangent of arctangent of x normally its aqual to x but when i run i found another value so why ?
and why the tan(arcTang(x)) not equal to x ?
Message 1 of 12
(6,365 Views)
Think DATAflow: Your VI calculates the arctangent of the tangent of x.
Kudos are welcome...
Message 2 of 12
(6,356 Views)
Accepted by topic author zaki_Khan
Message 3 of 12
(6,342 Views)
Same here, at least halt of it, the upper part is the arctan(tan(x)) and hence another calculation than the formula node.
Message 4 of 12
(6,327 Views)
sorry for being a troll...
Message 5 of 12
(6,306 Views)
I'm sorry for my previous reply, I mis-read the question of the OP.
@zaki_Khan: tan(arctan(x)) = x is only valid for x-values (in rad) between -Pi/2 .. Pi/2 (or -90° .. 90° in degree).
Regards
Message 6 of 12
(6,283 Views)
All trigonometric functions are periodic. This means for every Y, there is an infinite number of valid X values. The inverse function will give you an X that is normalized into a defined range. Check the help what the normalized range is (e.g. 0..180, -90..90, etc. or the equivalent in radians).
Message 7 of 12
(6,272 Views)
Also don't forget the Two input inverse tangent function Very useful because it maps into all four quadrants.
Message 8 of 12
(6,268 Views)
thank you
Message 9 of 12
(6,204 Views)
thanks ,
Message 10 of 12
(6,203 Views)
