tdms log duration wrong in Signal Express
Hi all, i set up a test to collect volts data per second, it was to run over 3 weeks, I used Signal Express but i have found that the log duration is wrong, it reports 16 minutes and 12 seconds, but ran for 11.25 days. IS there a way to tell it Days or Hours?
i am also concerned about interpreting the tdms log file, that number of points i have per second dont equal the overall runtime, and as data is not entered with a column timestamp im a bit puzzled,, im dowloading Scout (3rd part tdms viewer via NI) to see what it shows me,,,
see below for original file, note size versus duration,   Any assistance greatly appreciated, steve
Log name: 18/07/2014 11:19:53
User: LabTest
Project name: Untitled 1
File name: C:\Users\LabTest\Documents\SignalExpress Data\18072014_111953\Voltage.tdms
File size: 6.24486MB
Log duration: 16 minutes, 12 seconds
Log dt (s): 1m
Log iteration length (s): 1
Number of sample in log: 972000
Log datatype: Time-WDT-Real
Unit: V
Log start time: 18/07/2014 11:19:59.459
Time zone: GMT Daylight Time
Writer name: SignalExpress 2013
Writer version: 7.0
File format version: 2.1
Log signal names:
18/07/2014 11:19:53 - Voltage - Dev1_ai0
Alarms:
None
Start conditions:
None
Stop conditions:
None
(2,769 Views)
answer is i was looking at wrong file, ! Smiley Embarassed
(2,768 Views)
