tektronix PS2521G Programmable Power Supply
I have a Tektronix PS2521G Programmable Power Supply and I need for each channel to output a different voltage. I used the VI in the function palette, but when I changed one output, the other output changed as well. Can you help? Thanks.
(2,758 Views)
What VI did you use in the function palette? Did you first use TKPS252XG Configure Tracking to set the channels to track independently?
(2,758 Views)
Thanks, it works now 😛
(2,758 Views)
