Can LabVIEW sample an analog signal at 100 MHz?
I am interested in using LabVIEW as a high frequency oscilloscope. Can LabVIEW sample an analog signal at 100 MHz?
(2,557 Views)
LabVIEW is a great programming environment for oscilloscope measurements. You will need something to digitize the signal. I recommend the NI 5122 100 MHz, two channel, 14-bit, digitizer.
Dan Press
PrimeTest
www.primetest.com
(2,557 Views)
