Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Can LabVIEW sample an analog signal at 100 MHz?
ten10ten
Member
05-27-2004
01:54 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am interested in using LabVIEW as a high frequency oscilloscope. Can LabVIEW sample an analog signal at 100 MHz?
0
Kudos
Message
1
of 2
(2,558 Views)
Reply
Re: Can LabVIEW sample an analog signal at 100 MHz?
Photon_Dan
Active Participant
05-27-2004
02:20 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
LabVIEW is a great programming environment for oscilloscope measurements. You will need something to digitize the signal. I recommend the NI 5122 100 MHz, two channel, 14-bit, digitizer.
Dan Press
PrimeTest
www.primetest.com
0
Kudos
Message
2
of 2
(2,558 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
