template vis from right click menu
Hi all,
I've searched and could not find any posts with this situation.  I have made a template vi, and saved it in a subdirectory in Labview's built-in templates folder.  Then, I've added it to a new palette so that I can access this template quickly and base a new vi on it.
My problem is: when I click this template in my new palette, the template gets placed as a subvi in my blank diagram, and the icon has a blue "T" on it.  If I double click this icon it opens the template itself.
What I want:  when I click the template in the palette, I want to place the template's block diagram on a blank diagram that I already have open.
If I double click the vit in Windows Explorer, it opens a new vi with my template in it (which is good, but I don't want to have to click from Windows all the time).
Is there a setting or property that I missed?  I know this is possible, I've seen it done with other custom templates (such as the JKI Toolkit templates).
Don
(3,149 Views)
Accepted by drmase13
Take a look at this nugget by Yair.
They used to be called Merge VI's so I found it using a different search.
Ben
(3,143 Views)
Ah, thanks, Ben.  That was it.
In LabView 8.6 it's named as "Place VI contents" which is self-explanatory but I did not think to look in the right click menu while customizing my palette.
 Place VI Contents
Message Edited by drmase13 on 10-05-2009 01:47 PM
(3,137 Views)
The new method of doing about the same thing is called snippets:
http://labviewwiki.org/Snippet
Worth looking at if you found yourself here in a search on vi templates.
(2,721 Views)
