text file convert to string array
I tried to convert text file to string array. But it is not successful.
 text file :
 SD, 1,2,3,4
 GD, 3,4,5,6
I use spreadsheet string to Array function but ALL characters is become to zero.
 my result:
  0,1,2,3,4
  0,3,4,5,6
(10,159 Views)
Hi, Its very simple. Try this.
Hope this helps you.
(10,144 Views)
you can see my previous attach fife. I also do this way but  all character convert to  number 0. I do not know why ..... ??
(10,132 Views)
pls post your VI in version 2009.
(10,128 Views)
I do not have Labview 2009
(10,114 Views)
Hi Hieu,
try it that way:
When you want a string array you have to provide the corresponding constant at the lower left input of "spreadsheet string to array"...
(10,103 Views)
indeed the solution of GerdW is the way to do it, except for the fact that the while loop isn't needed in this case 😉
Have fun using LabVIEW
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(10,095 Views)
