text file transfer from myRIO to remote PC in a while loop for control
I am trying to transfer a text file on my desktop computer to myRIO and also read a text file from myRIO to my desktop computer. The control algorithm is running in python on my desktop computer. I tried with WebDAV from the following link but couldn't open a new text file in myRIO? It says permission not granted, but I can see different folders in the files folder.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019PlESAU&l=en-US
Wondering if I am doing something wrong.
I also read that it is not a good idea to transfer file in a while loop. I need to obtain the states (which are in the text file) in order to output the control signal from python in my desktop.
I am attaching the VI which tries to read and write files in the myRIO. Using WebDAV I wanted to read and write these files from myRIO.
Is there a better way to do this?
(3,376 Views)
Accepted by nku1991
Why write a file?  Setup a network communication so that your PC application can just request the data and then your myRIO just sends the latest values up.  On the myRIO, you will want a second loop to handle this communication and probably a simple Global Variable to hold the latest values.
(3,363 Views)
Hi crossrulz,
Do you have any suggested link where I can setup a network communication?
(3,344 Views)
@nku1991 wrote:
Hi crossrulz,
In LabVIEW, go to Help->Find Examples.  Just do a search for "TCP" and you will see a Simple TCP.lvproj.  Use that as a starter.
(3,331 Views)
