the default size of the indicator does not fit the default display format
Dear LabVIEW fellows and LV support,
the default size of a bewly created indicator does not fit (in width) the default display format (Automatic formatting). Is there any possibility to set a different default format of the indicator/control or a different default display format of those, please?
Cheers, M
(2,218 Views)
You can create a custom control with the properties you want and add it to the palettes - https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/dialog-boxes/edit-controls-and-functions-p...
___________________
Try to take over the world!
(2,209 Views)
