the elapsed time problem !!
1 the first timer runs until the red needle on AGI reachs the value X by moving the dial2 then it stops
2 the second timer runs after the first one stops
the problem is : when i reach the value X the red needle can't move anymore and the second timer doesn't stop until its limit
what i want is :- keep controling the red needle of AGI even when i reach the value X so i can move it away whenever i want
                        - the second timer must stop once i move the needle from the value X
-90<X<90
thank you
AR
Message 11 of 20
(2,389 Views)
-90<X<90
thank you
Okay, so after you move the needle again, what happens?  Is it supposed to go back and execute from the beginning with the new needle value?
Bill
CLD
(Mid-Level minion.)
Message 12 of 20
(2,386 Views)
in the program the needle of AGI is stuck at the value once it reachs it, i can't move it anymore
but i want that it moves as the needle of dial2 moves. then the second timer will stop once i move it away from the value X
BTW the program must not to be run continuousely
thank you
AR
Message 13 of 20
(2,379 Views)
you're not using the "run continuously" button, are you?  that button should NOT be used except as a debugging tool.
Bill
CLD
(Mid-Level minion.)
Message 14 of 20
(2,375 Views)
hey i saw your program. but i want to control the dial2 while the execution of the program.
and my probleme is about the elapsed time while the red needle of AGI maintains the value.
thank you
AR
Message 15 of 20
(2,371 Views)
hi,
Is that what you want ? (see attachment)
(P@Anand is right.... add delay to my loop if you use it, even 1ms delay)
Message 16 of 20
(2,370 Views)
no the run continuousely button shall not be used to have a correct execution
AR
Message 17 of 20
(2,368 Views)
hi @amitai ur program is good but not what i want because it stops once i get to the value X that i define
i want to calculate the elapsed time to reach the value X also the elapsed time before i leave it again then it should stop
AR
Message 18 of 20
(2,355 Views)
Accepted by ABDESLAM
the second timerin my example is in milisconds,
Change it to 5000 (ms)
and change the dial above the setpoint from the Digital Display
Message 19 of 20
(2,347 Views)
hey "amitai.abramson" :
you did it my friend !
thank you very much 🙂
and thnaks to all of you guys for helping
AR
Message 20 of 20
(2,323 Views)
