the path is empty or relative. you must use an absolute path
Hi, I have problem while running my labview program. It say "the path is empty or relative. you must use an absolute path". anyone can help me? I attach the error screenshoot below. thank you
(4,670 Views)
Accepted by raayr
Hi raayr,
do as the error message says: use an absolute path!
How did you create this "u//labviewgarek.csv" string? What is the expected path?
Why dont you attach your VI when you have problems with your VI?
(4,663 Views)
Accepted by raayr
What is your OS? (Since you use forward slashes, it's probably not windows)
(Your path is definitely malformed, but unfortunately we cannot see your code. Do you use "build path" or plain string operations? What is the path supposed to be?)
(4,644 Views)
Accepted by raayr
I'm guessing an error happened upstream that led to an empty string being part of your path instead of whatever was supposed to go there.
Bill
CLD
(Mid-Level minion.)
(4,624 Views)
Accepted by raayr
Since it looks like you are trying to write to the U drive and the forward slashes, I'm guessing you are using a cRIO.
But "//" being in your path indicates that you are missing something in your file path.  Check for any upstream errors.  Something returned an empty string.
(4,614 Views)
Accepted by raayr
On crio, an absolute path should start with a "/" (details).
Could it be the path root is mistyped and should be "/u" instead of "u/"? (Maybe correct path is /u/labviewgarek.csv instead of u//labviewgarek.csv).
(4,587 Views)
