thermotron
HELP NEEDED!!!!
Do you have any program that control THERMOTRON ovens? i wish to use Labveiw drvers
I need something very simple that only sets the temperature
We have here model 2800 and 3800 (s-1.2,s-1.2c)
Please let me know if you have something available
Shai
Message 1 of 25
(6,101 Views)
Wasn't this question already answered here and here? If you have problmes with any of the answers, you should reply on the same thread and not start a new thread and if you have problems with any of the drivers/code provided in the other threads, you should explain exactly what the problem is.
Message 2 of 25
(6,093 Views)
This is a different problem:
It is error 1073807298:
TH4800 Manual.vi<ERR>Driver Status:  (Hex 0xBFFF003E) could not perform operation because of I/O error.
Elaboration: Attribute: TH4800_ATTR_STATUS_BYTE
More information:
I am using Labview 7.1
Thermotron drivers for model 2800 and 3800
The model of the instrument is s-1.2c
Message 3 of 25
(6,081 Views)
It seems like you are using the IVI driver that was mentioned in one of the other posts. Do you have the IVI compliance package installed? You can check that in MAX. You should read the information at http://zone.ni.com/devzone/cda/tut/p/id/3377 which also contains a link to the compliance package.
Message 4 of 25
(6,075 Views)
I am using ordinary VIs
Message 5 of 25
(6,066 Views)
I'm not sure what you mean by ordinary VIs. Can you post the VI that you are using?
Message 6 of 25
(6,063 Views)
I have downloaded from Thermotron website their Lab view drivers for the 2800
some of them seem to work just fine
but some give me the error i mentioned before
what do you want me to post?
Message 7 of 25
(6,060 Views)
Either just the VI that is giving you an error or the whole driver that you downloaded. The whole driver would be best. I'm willing to take a lot at it to see if there's something obivous but without the chamber, there's not much I could do beyond that and since the driver was written by Thermotron, your best bet for resolution of the problem may be to ask them.
Message 8 of 25
(6,055 Views)
Is there an option to attache the folder in here?
can I e mail it to you? (send me your e mail adress)
ps
i appreciate your help
Message 9 of 25
(6,046 Views)
There is an option to attach files. Right below this message body, you'll see a box labeled Attachment with a browse button. Click on the browse button and select the file. After you've attached one file, you can click on the 'Add Additional Attachments' if you want to add additional files. If the driver is in an llb, you can simply attach that. Otherwise, zip the separate files together and attach that. DO NOT click the Preview Post button after attaching files. You lose the attachment that way.
Message 10 of 25
(6,042 Views)
