time format code
hi
how do i set the time format code to give milliseconds? if i use %s i get seconds, %M i get minutes etc.
thanks
(3,468 Views)
The general format is %u as you have but you need to replace with an actual number. The number is the precision you want.
(3,467 Views)
hi
i changed it to %<3>u but it only displayed <3>U
(3,461 Views)
What I meant to say was the %u was the general format and you replace with a number. Do not use < or > in your format string. %3u is what you want to use.
Message Edited by Dennis Knutson on 03-08-2005 10:45 AM
(3,459 Views)
thanks
working perfectly!
(3,451 Views)
