time slot problem
I am stuck with a problem.  I have to assign timing to the task for load prioritization . If my grid supply gets OFF, during 08:00 Hr to 20:00 Hour then my diesel generator should get ON for Load A and if my grid supply gets OFF after 20:00 Hour till morning 8:00 hour of next day the same diesel generator should get ON for Load B. this turning ON of diesel generator should have delay of at least 2 minutes. should i use timed loop or sequence, if yes please tell me how?
Message 1 of 22
(6,618 Views)
Try a state manchine.
Message 2 of 22
(6,611 Views)
Hey Thanks!! I am just developing logic, does state machine require interfacing?
Message 3 of 22
(6,604 Views)
I don't understand the question. What do you mean by "Logic"? by "interfacing"?
Message 4 of 22
(6,596 Views)
By interface, I mean does it will require DAQ asst. to check grid supply and system timing to ckeck time? And By Logic I mean, I am just writing prog in Labview.
Message 5 of 22
(6,585 Views)
how would I give time. i am able to introduce wait, I took current date time and add a wait to current time, to introduce delay, but i m not getting how to assign timing? Please help me.. i m stucked here since last 7 - 8 days.
Message 6 of 22
(6,583 Views)
Can you share your code?
Guilherme Correa
Message 7 of 22
(6,568 Views)
Accepted by nehaom
Maybe something like this can help you:
Norbert
Norbert
Expert: Geometry
Message 8 of 22
(6,563 Views)
yes, i can but you might not get it, since other logic are also involved. and the defined problem is part of prog
Message 9 of 22
(6,555 Views)
i need the solution. how can i share the problem in detail with you. Ok. i am forwarding the code, please check and recommed the solution. It is for 100 KVA Diesel generator the defined problem (If my grid supply gets OFF, during 08:00 Hr to 20:00 Hour then my diesel generator should get ON for Load A and if my grid supply gets OFF after 20:00 Hour till morning 8:00 hour of next day the same diesel generator should get ON for Load B. this turning ON of diesel generator should have delay of at least 2 minutes. ) to be implemented.
Message 10 of 22
(6,549 Views)
