time string to time stamp
Hi Everyone ,
I have two time strings :
05-06-2009 > 02:00-03:00
13-06-2009 > 05:00-06:00
I want to convert them into timestamp and then i want to compare them to know which one is older.
 If its possible without converting to timestamp then that would be good too but I guess the best way would be to convert the string to timestamp first.
Rgs
M Omar Tariq
(3,823 Views)
Did you get what you needed fronm the other thread? If so you should make this as solved.
Tim
GHSP
(3,812 Views)
No , i tried the same technique which is shown in the other thread but it didn#t work =(
Therefore can anyone help me out if possible
Thanx
Rgs
Omar
(3,809 Views)
Accepted by OmarTariq
Its now working ,
Thanx , I was doing a mistake, the following thread solution works
http://forums.ni.com/t5/LabVIEW/timestamp-conversion/m-p/1283734/highlight/false#M533356
Rgs
Omar
(3,805 Views)
