 Sachindian
			Sachindian
			08-15-2013 08:46 PM
i am trying to generate time signals for which i have values in matlab. I am trying to figure out a way to take this data in to simulate arbitary signal vi. I am unable to convert the data from mat file to lvm file. is there a way to do this.
 Florian.Ludwig
			Florian.Ludwig
			08-16-2013 09:20 AM
I'm sorry but I'm unfamiliar with matlab. When you say: "I am trying to generate time signals for which I have values in matlab.", do you mean you have the parameters for a function (e.g.. sine wave, amplitude.pp 1, phase 45°...)?
Or do you have the data of a complete waveform wit a list of xy pairs?
What does that mat file look like?
Regards
Florian
08-18-2013 06:54 PM
My mat file is a time values of the signal for one period. I want to replicate these values to form a complete signal.
The values are in two columns first is time and second is amplitude. I have taken 1000 samples for one time period of signals.
I will be generating such files for differency frequency signals. how to convert them into readable format in labview.
 Dennis_Knutson
			Dennis_Knutson
			08-18-2013 07:19 PM
 moderator1983
			moderator1983
			08-19-2013 03:55 AM
@Dennis_Knutson mentioned correctly, same signal can be generated in LabVIEW...!!
but if the constraint is, you only have the data file (.mat file) and no MATLAB code, probably you may want to check following links:
