timestamp compact fieldpoint
The timestamp on the LabVIEW RT front panel of my  compact fieldpoint device (cFP-2100) is diplaying the correct date, minute and second, but the hour is incorrect.  I've tried adjusting from universal time in MAX which changes only the hour, i set the IP for time server in MAX to my computer's IP address.  In LabVIEW when convert the timestamp to a string, i get to different readings for the string and the timestamp indicators.  How can i fix the hour on my timestamp, in string format?
Message 1 of 1
(2,669 Views)
