timestamp rounding problem
In a state machine I'm setting the current time for a process as the start time and adding 6 hours for end time in the initial state. Later in the 7th state, i can change the start time and the second/ms value rounds off (e.g. 12:30:00.000 PM) but the end time when changed rounds off to say 4:20:39.333 PM. But I want it to look like 4:20:00.000 PM. What do I do? [Increment value for both are 60, coerce down]
Message 1 of 17
(7,180 Views)
Attach your vi or a code snippet so we can see what you're doing, then maybe someone can comment on how to fix it.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 2 of 17
(7,176 Views)
tabs-FS is the main VI and 6hours is the subVI used. Look into Initialize and Scheme states of tabs-FS. Other subVIs are too large to attach. Thanks.
Message 3 of 17
(7,174 Views)
For the indicator, truncate the wire value to a multiple of 60 using code, e.g. as follows:
Alternatively, you can change the display format to omit the seconds. (see image)
No need to show the seconds....
Message 4 of 17
(7,165 Views)
Accepted by shreya005
Also note that the subVI code could be simplified dramatically.
You don't need to unbundle-rebundle all elements, just the one that changes (hours, top image)
Even simpler, add the number of seconds to the timestamp (bottom image).
Message 5 of 17
(7,164 Views)
@ thanks for the simplification for addition of 6 hours. but the rounding off problem still exists. even though the display format is as required, the exact values in the probe watch window show the 39.333s in the end time. As this is to be implemented for a practical application later, it has to be exactly 6hours, cannot have the 39.333 seconds
Message 6 of 17
(7,152 Views)
Did you try the two methods I showed above (truncate the timestamp in the wire going to the indicator or change the display format). If you don't show seconds, they cannot be wrong 😉
Message 7 of 17
(7,132 Views)
i implemented the truncate function it works. thanks 🙂
Message 8 of 17
(7,122 Views)
Jim Kring posted a few years ago on his blog a cool feature of timestamps; they support units!
You can set the units for the constant to hours and add that directly to the timestamp; no units scaling required...
(Oops; looks like altenbach commented on that blog, you already know about this)
http://thinkinging.com/2007/06/08/labview-tip-easy-relative-timestamp-calculations/
Message 9 of 17
(7,107 Views)
Doesn't mean that old... umm... hands... don't need reminding every so often.  😉
Bill
CLD
(Mid-Level minion.)
Message 10 of 17
(7,079 Views)
