timestamps and calendar types for x-axis in graphs
I wonder if anyone could help me regarding this problem:
I want to display a waveform which consists of an array of numbers (Y array) versus an array of timestamps (x-array) on a graph. I do know how to change the format of x-axis to show timestamps, but the big problem is that my timestamps are not in Gregorian calendar! They must be in our own local Persian calendar. I can not define any time stamps in Persian type because the default Labview timestamps are in Gregorian...
I appreciate if anybody could guide me how to show my Persian calendar timestamps on x-axis of a graph.
Mahshid
(3,158 Views)
Hi Maah,
similar request to yours are of type "how to display some kind of text on the x axis of graphs": they mostly come to the result of hiding the x axis of the graph and use your own string display instead. With an ordinary string you can display anything you want in any formatting you like.
Other solutions use the 2D picture indicator to draw your own graph with all elements (axis, gridlines, legend, ...) on your own…
Ohh I forgot: Welcome to the forum!
(3,150 Views)
To make all this easier in the future, feel free to give kudos to this idea. 😄
(3,117 Views)
Hi GredW,
Thank you very much for your guide and greeting.
I 'll check thier solutions and let you know the results.
Regards
(3,061 Views)
