timing - fpga
I am working on fpga project based on Delta-Sigma data acquisitsion. Now I am testing it in the hardware. In the acq. loop, there is tic counter which I took from NI samples, When I run it it count bilions of tick and there is not signal from DMA. It does not working and I do not now why.
Does someone has an idea ? Check Main.vi in the project.
I am not sure about IRQ signal and that I answer it correctly but I think the main acq. loop does not run till IRQ is acknowledged so the tic counter would not count anything.
There is file [FPGA]Main.vi which is the main vi of the project.
(2,899 Views)
Hellllllo....
could somewone try to help us??
i need also a vi called `Sample Rate to Loop Time.vi`, he has a polimorphycal behaviour .
cold somewone send me this file ??
thx
Jimi
(2,873 Views)
I don't have any idea what's wrong here, but I would try running it in simulation on your PC and see if you can find the problem using the standard LabVIEW debugging tools.  See "Testing an FPGA VI Called by a Real-Time VI Running in Emulation Mode."
(2,854 Views)
