usrp2920 reverse signal
Hi!!
I'm trying to built a little radar with the USRP 2920  ..
but I have a problem.
I connect the two port of tghe USRP (TX1 RX2) with a low loss cable of 50 cm..
after transmitting a chirp signal, sometimes  i found my signal on rx port shifted by 180 degrees .. totally reversed
it's possible that is a problem of the LNA on board of the USRP ?.
Francesco
Ps
I Had this problem also with the USRP 1 of Ettus
(2,387 Views)
you may be assisted better if you post your question at NI USRP
Yupeng J.
(2,376 Views)
