to open hide function
Hi everybody,
Code of some functions is hided. That is, I don't add control or  indicator.  SubVI is cerated in some function and I don't open the subVI.   to open the subVI and add control or indicator in the function, What can I do?
(2,972 Views)
I'm not sure what you are asking. If you are trying to modify a VI that is password protected, then the answer is, no you can't modify it. What function and why do you need to change it?
(2,945 Views)
