to put variables in sql request?!
How i can to put variables in sql request?!
Thank youu for your help.
(4,630 Views)
Accepted by imadouino
Format Into String
Jim
(4,603 Views)
This is exactly what I was looking for
Thank youuuuu
(4,600 Views)
I'm sorry to disturb you but, why I get commas instead of points in the result?
(4,589 Views)
LabVIEW uses your regional number formatting settings from Window.
For instance your Windows is set to French, then  you use a "," (comma) as number decimal separator instead of a period that you would get if you used English (US).
(4,567 Views)
Its better to use bound parameters if your SQL library supports it.  String formatting may work for "input 4"="jcarmody", but will fail for "jcarmody's".  Even worse is "jcarmody');drop table Banc2".
(4,563 Views)
@drjdpowell wrote:
[...]Even worse is "jcarmody');drop table Banc2".
Oh. Yes. Little Jimmy Tables, we call him.
exploits_of_a_mom
Jim
(4,548 Views)
