to store
Hi kausi,
for me it looks good. I don't use LVM files at all & don't have much experience in those ExpressVIs...
Message 21 of 23
(604 Views)
 Respected sir
              can anyone help me to linearise the waveform chart. i used the chart to display the analog output from the pressure sensor.
i gav input pressure as mounting it on our wrist,so it includes mounting pressure an well as pressure exerted by our Radial Artery pulse
so it comes as different output voltage (y axis)waveform from each other... i have to linearise(y axis) this chart as output starting from zero...
please find the attachment..
thanking you.
Message 22 of 23
(581 Views)
Hi kausi,
when you want your "output starting at zero" you have to remove the offset.
Easy as it is: subtract the first measurement value from all following values...
Message 23 of 23
(576 Views)
