tortoisesvn
After installing and setting up the latest LVDIFF software, i get a couple of unwanted popup`s during comparison.
I open "show log" from Tortoise and then right click on the wanted file and select "compare with working copy".
The 1st pop up states, "The file C:\Documents and Settings\grant_cargill\Files\National" is not a valid LabVIEW file.  I dont have a file called files\national.
Then 2nd pop up states the same but with a different unknow file.  This time it is ........grant_cargill\Instruments\LabVIEW" is not a valid file.
Has anyone experienced this fault or know of a setting to get rid of it.  After the pop-ups are OK`ed, they clear and the comparison seems to work fine.  The file i was comparing is in my workspace.
Grant
(3,476 Views)
Also, I am using Labview 8.2.
(3,446 Views)
  unfortunately LVDIFF and tortoise are both third party products so in terms of lvdiff you're going to need to talk to Mike Porter who I beleive designed some fixes for the it
http://sourceforge.net/projects/meta-diff
This next link is a thread Mike Porter was on about 6 months ago with documentation on using the scc, so may be of help :
http://forums.ni.com/ni/board/message?board.id=170&message.id=138937&requireLogin=False
There has been a tiny amount of discussion on the appropriate forums here : http://sourceforge.net/forum/forum.php?forum_id=93335 so I think it's active for you to post your question to lvdiff developers.
Please let me know if we can be of further help.
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(3,436 Views)
