touch panel pop up windows
I am using the touch panel module to build an application onto a NI TPC-2106T. I am finding that if I use functions like a dialog box, or call the front panel of a sub VI, nothing happens in the touch panel display. Is this because the pop-up windows need to be positioned correctly, or does the touch panel not support this kind of thing?
mstudio
(2,654 Views)
Hi there,
With reference to this thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=317640&requireLogin=False
Some of LabVIEW's features/functionality operates differently with the Touchpanel Module, or is not available. The above thread mentions about the behaviour of pop up subVIs, so this should help you with your question.
Dan - NIUK
(2,600 Views)
