trafag pressure transmitter ouput
What sort of values do you actually get? How have you configured the acquisition (rse, diff) and what pins did you connect? What do you read in the MAX test panel?
Message 11 of 20
(2,537 Views)
i got values between -95 and +45.Firstly i asked, what is the difference between diff and rse which one should i do?i connect acquire data-analog input-voltage-ai6
Message 12 of 20
(2,534 Views)
and acquisition mode is continuous sample
Message 13 of 20
(2,531 Views)
Diff = differential
Rse = referenced single ended
You should be using differential.
I asked for pin numbers, not names but you only provided a single name. No idea of you connected gnd or the second channel of a differential connection.
Message 14 of 20
(2,511 Views)
pin1:+
pin3:output
pin4:-
Message 15 of 20
(2,499 Views)
That does not make any sense. For a differential connection, you connect ai0 and ai8 - pins 1 and 2 with the usb device and the screw terminals. Did you look at the connection diagram given in MAX or the DAQ Assistant?
Message 16 of 20
(2,492 Views)
I connect signal to ai0.for differential connection, where am i suppose to wire power supply - in this DAQ?Could you please comment on this figure.For ex. there exist AI8 but in DAQ surface i cannot see it
Message 17 of 20
(2,470 Views)
In MAX i tried to look at it but is says; the connection diagram tool does not support this device
Message 18 of 20
(2,466 Views)
http://www.ni.com/pdf/manuals/375204a.pdf this is my device's manual.at page20-21-22 say something about you said but could you please physically tell me how to do it?
Message 19 of 20
(2,454 Views)
i have solved it. ai0- is round metal cylinder 🙂
Message 20 of 20
(2,435 Views)
