transfering a case structure to event structure
This entire thing needs to be recoded as a proper state machine instead.
Message 11 of 12
(348 Views)
This.
It's probably the easiest and best solition in this case. Think and define which different phases the program uses and make a state machine with those.
It'd be something like:
Initialise
Grab image
Calculate
Save image
End or goto Grab image
If the states are a typ def'd enum (which it should be), it's easy to add states as needed.
Check Help, Find examples, State machine.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 12
(341 Views)
