transparent of block diagram
Hi all,
I want to make all structures in the block diagram transparent and want to write annotation to related places on block diagram. How can I make all elements of the block diagram transparent?
(2,599 Views)
Any particular reasons for making the structures in the BD transperent? if you are worried about some unauthorized access to the BD then you an always password protect it..
Regards
Guru (CLA)
(2,586 Views)
Or save without BD.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
(2,572 Views)
I think he is more thinking about functionality as common in Visual Studio:
Collapse/Expand parts of the code (like namespacing area) and instead give some little documentation like
// tricky algorithm here
I suggest you to work with subVIs. They will solve most of the requirments you are after if i understood your question correctly.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,564 Views)
