tree structure
Hello all.
I have a map of a building that is presented in a tree strcture, where each node represents a room. I need to find a way to implement this tree in LABVIEW for finding the route from one rooom to another. For eample if anyone wants to go from room E to room D , the route will include passing along rooms A then B ( see the attachement please)
thanks,
(4,072 Views)
Labview has a Tree control.
Just eplement the structure..
Then from a room, go one step back (to the parent) and check if the room you want to go is a child. If not go another step back and do the same.
It should be quite easy.
(4,060 Views)
One easy shortcut is using paths.
In LabVIEW.8.x a primitive 'relative' path is introduced that will give the relative path between to paths.
For LabVIEW 6.x and 7.x OpenG has a similar function
Ton
My LabVIEW Ideas
(4,037 Views)
Sorry , Can you help me more, by explianing more or give example?
(4,028 Views)
