trouble adding times to graphs
Joel,
The attached file has a llb extension. Can you please send the VI. Thanks! again for all your help.
MH
Message 11 of 16
(650 Views)
Your Labview should be able to open the llb or labview library file. But anyway, ignore the previous response. Here is a modified VI to show you where to connect your analog input. On the diagram, replace the small sequence frame where the random number generator inside in a green background color (to make it easy for you to find) with your analog input. Here, I'm using a double numeric datatype. You need to acquire a single data point or measurement from a single analog input channel. Good luck!
Message 12 of 16
(650 Views)
Joel,
The grpah works very well! Thanks for all your help. I am now going to move on and try to figure out how to log 15 min values in a ASCII file to view later. Thanks again from all your help
MH
Message 13 of 16
(650 Views)
Joel,
Where exactly to I format the time. I would like the date below the time. It doesn't have to be fancy something like 08-12 or Dec 8 etc.
Thanks again,
MH
Message 14 of 16
(650 Views)
Either in the property page for the graph, or in the Scale Formatting
dialog, depending on which version of LV you are using.
Greg McKaskle
Message 15 of 16
(650 Views)
Here's the modified the VI with the new time/date format. I hope this will help in your project in somehow. Anyway good luck!
Message 16 of 16
(650 Views)
