Your Labview should be able to open the llb or labview library file. But anyway, ignore the previous response. Here is a modified VI to show you where to connect your analog input. On the diagram, replace the small sequence frame where the random number generator inside in a green background color (to make it easy for you to find) with your analog input. Here, I'm using a double numeric datatype. You need to acquire a single data point or measurement from a single analog input channel. Good luck!
