trouble with functions/controls palettes
Hello Candice,
Have you tried Deselect All in the Change Visible Categories?
Can you verify that the path that LabVIEW is installed on? It should be C:\Program Files\National Instruments\LabVIEW x.x.
Andy Chang
Message 11 of 19
(1,944 Views)
Oh my goodness, I asked it to deselect all, and now I don't even have an option for "Select VI" now! AND now I can't select anything out of the functions palette, let alone let alone right click to select a vi.
Message 12 of 19
(1,937 Views)
Perhaps this will help. When I press "Search" on the Functions palette, Labview crashes:
Message 13 of 19
(1,931 Views)
Also, when I ask it to show me the quick drop menu on the BD, it crashes.
Message 14 of 19
(1,926 Views)
Accepted by Candice
Problem solved.
Since uninstalling and reinstalling the 2nd Quarter 2009 gave me this failure twice in a row, I decided to use my 1st Quarter 2009 disks, and that worked. It must have been some problem with installing those bad boys from scratch.
Thanks for everyone's help and input, and sorry to take up so much space with this.
Message 15 of 19
(1,913 Views)
Turns out the problem is not solved. Now I have the same issue on the FP. So if anyone has any ideas, please let me know. The idea of reinstalling this for the effectively 5th time apalls me.
Message 16 of 19
(1,883 Views)
Can you try a repair of LabVIEW rather than uninstall?
Message 17 of 19
(1,875 Views)
I already did; nothing happened.
Message 18 of 19
(1,873 Views)
Hello Candice,
Have you taken a look at this KB yet?  It gives a couple of different suggestions on how to get around this issue.  Also you mentioned that the problem was resolved, but then it appeared again on the front panel.  Does everything still look alright on the block diagram?
Message 19 of 19
(1,854 Views)
